Re: [Nagios-devel] Nagios status sounds only when max_check_attempts
Dear,
This is indeed a nice improvement. However, sound warnings are still a
no go here as long as it keeps on beeping on every page refresh...
Kind regards,
Tom
Saner, Markus wrote:
> Hi all,
> status sounds are very usefull when working near a Nagios browser client.
> In our configuration most mails, pager and sms messages are sent only
> during non working hours. The rest of the time we use the sound of
> Nagios as indicator for failures, because there is allways someone or
> another near the console, where a Nagios browser session is running as well.
> We experienced that Nagios will play sound at the first time it
> recognises a warning or critical stage. This can be very annoying when
> for example a ping reply reaches warning or critical level for a short
> time and then fall back to normal again. If this happens to often,
> operators lose interest in looking at Nagios.
> Increasing warning or critical level is not a real option, because i
> want to recognise these levels but only when they occure for a
> defined time, (max_check_attepts).
> We would wish to implement playing sounds only, when max_check_attepts
> is reached, as for sending pager, sms or emails.
> I implemented this option in tac.c some weeks ago, and everybody is
> happy since then.
> Attached you will find my modifications to tac.c, (marked with SAN).
> This was only a quick hack and could may be done differently. Of course
> the same modifications must be done in status.c.
> Any other ideas ?
> Thanks and regards,
> Markus Saner
