[Nagios-devel] nagios CVS postgresql 7.3 fix
--HlL+5n6rz5pIUxbD
Content-Disposition: inline
This allows nagios-cvs to run successfully with postgresql 7.3.
I just fixed the timestamp conversions. This should be backward-compatible=
down to at least postgresql 7.0, maybe even 6.5.
Is this the proper place to pipe patches?
Index: xcddb.c
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
RCS file: /cvsroot/nagios/nagios/xdata/xcddb.c,v
retrieving revision 1.3
diff -u -r1.3 xcddb.c
--- xcddb.c 2 Dec 2002 04:30:12 -0000 1.3
+++ xcddb.c 4 Jan 2003 00:02:37 -0000
@@ -711,7 +711,7 @@
snprintf(sql_statement,sizeof(sql_statement)-1,"INSERT INTO %s (host_name=
,persistent,entry_time,author_name,comment_data) VALUES ('%s','%d',FROM_UNI=
XTIME(%lu),'%s','%s')",XCDDB_HOSTCOMMENTS_TABLE,escaped_host_name,persisten=
t,entry_time,escaped_author_name,escaped_comment_data);
#endif
#ifdef USE_XCDPGSQL
- snprintf(sql_statement,sizeof(sql_statement)-1,"INSERT INTO %s (host_name=
,persistent,entry_time,author_name,comment_data) VALUES ('%s','%d',abstime(=
%lu),'%s','%s')",XCDDB_HOSTCOMMENTS_TABLE,escaped_host_name,persistent,entr=
+ snprintf(sql_statement,sizeof(sql_statement)-1,"INSERT INTO %s (host_name=
,persistent,entry_time,author_name,comment_data) VALUES ('%s','%d',%lu::abs=
time::timestamp,'%s','%s')",XCDDB_HOSTCOMMENTS_TABLE,escaped_host_name,pers=
istent,entry_time,escaped_author_name,escaped_comment_data);
#endif
sql_statement[sizeof(sql_statement)-1]=3D'\x0';
=20
@@ -809,7 +809,7 @@
,service_description,persistent,entry_time,author_name,comment_data) VALUES=
('%s','%s','%d',FROM_UNIXTIME(%lu),'%s','%s')",XCDDB_SERVICECOMMENTS_TABLE=
,escaped_host_name,escaped_svc_description,persistent,entry_time,escaped_au=
#endif
#ifdef USE_XCDPGSQL
('%s','%s','%d',abstime(%lu),'%s','%s')",XCDDB_SERVICECOMMENTS_TABLE,escap=
ed_host_name,escaped_svc_description,persistent,entry_time,escaped_author_n=
('%s','%s','%d',%lu::abstime::timestamp,'%s','%s')",XCDDB_SERVICECOMMENTS_=
TABLE,escaped_host_name,escaped_svc_description,persistent,entry_time,escap=
#endif
=20
Index: xdddb.c
RCS file: /cvsroot/nagios/nagios/xdata/xdddb.c,v
diff -u -r1.3 xdddb.c
--- xdddb.c 2 Dec 2002 04:30:12 -0000 1.3
+++ xdddb.c 4 Jan 2003 00:02:41 -0000
@@ -751,7 +751,7 @@
,entry_time,author_name,comment_data,start_time,end_time,fixed,duration) VA=
LUES ('%s',FROM_UNIXTIME(%lu),'%s','%s',FROM_UNIXTIME(%lu),FROM_UNIXTIME(%l=
u),'%d','%lu')",XDDDB_HOSTDOWNTIME_TABLE,escaped_host_name,entry_time,escap=
ed_author_name,escaped_comment_data,start_time,end_time,fixed,duration);
#endif
#ifdef USE_XDDPGSQL
LUES ('%s',abstime(%lu),'%s','%s',abstime(%lu),abstime(%lu),'%d','%lu')",XD=
DDB_HOSTDOWNTIME_TABLE,escaped_host_name,entry_time,escaped_author_name,esc=
...[email truncated]...
