Re: [Nagios-devel] Orphan hosts in hostgroup list
Bernd Arnold wrote:
>> For extra points, make it not create the host/servicegroups if they
>> aren't going to be displayed.
> I've done some improvements. The groups are only created for the CGIs
> if the config variables are set to 1. So now I've earned the extra
> points :) Just kidding...
>> Ethan, these patches look simple enough that it's worth applying
>> imo. It's also something some people have expressed wishes for. The
>> default should probably be to not show them though, and to not
>> create them when they're not to be shown. I can fix that later if
>> you like.
> The default is: they are not created in the main Nagios program. And
> the default for the CGIs is: they aren't created (and thus shown).
> If you like to apply them I've added extra parts for the config and
> html files, too.
> And now I know how to create one diff file for all changed files with
> cvs. By the way, is there an approach replacing cvs by subversion?
Why replace crap with crap? I'll get Ethan drunk in Germany during the
Netways conference and make him promise to swap to a distributed vcs. ;-)
OP5 AB www.op5.se
