Re: [Nagios-devel] Discrepancy between command definitions and
Thomas Guyot-Sionnest wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> The documentation for ACKNOWLEDGE_{SVC,HOST}_PROBLEM commands in Nagios
> 2.x and 3.x says to use 1 for sticky and 0 for non-sticky ack's; however
> the way it's currently implemented is using the following macros for
> non-sticky and sticky ack's respectively:
> include/common.h:#define ACKNOWLEDGEMENT_NORMAL 1
> include/common.h:#define ACKNOWLEDGEMENT_STICKY 2
> Looks like it's always been like that so I think the best would be to
> fix the documentation... At least for the current releases. OTOH this
> will leave broken any home-build script that send the command according
> to the documentation.
Are you sure it's not just a bitshift thing, like so:
foo->ack_type = 1 << ack_type_from_command;
That's how I'd have done it, and then let ack_type serve doubly as
"has_been_acked" sort of thing.
I haven't checked myself though, so I could be completely wrong (I'm
lazy today, as it's a fine spring day in sweden :-))
OP5 AB www.op5.se
on peace.
