Re: [Nagios-devel] Multithreading Segfaults :(
Steven D. Morrey wrote:
> I think I've got it mostly worked out now. Turns out lots of
> functions call eachother, thereby producing a race. The trick seems
> to be to ONLY lock the sections of code dealing directly with macro_x
> and not just the entire function dealing with macro_x itself. I'm
> going to give it 12hrs of run time and then I'll get a patch up for
> testing.
The "right" way of doing that is to lock down the global arrays in a
single file and then publish a thread-safe API to manipulate it. The
thread-safeness can be taken care of by the simple expedient of adding
locks to start with, and later one can modify the functions so that
hostnames etc are added in a function-local stack-allocated array
instead, which could potentially increase performance quite a lot
(and also reduce memory fragmentation quite a bit).
OP5 AB www.op5.se
on peace.
