Re: [Nagios-devel] ndoutils missing output column
--------------070806010007000200060401
Content-Type: text/plain; charset=ISO-8859-1
Hash: SHA1
Am 05.10.2009 16:23, schrieb shadih rahman:
> Hendrik, Thanks for your reply. how can I verify, that your nagios
> is using the new compiled binaries?
Timestamp of the installed file vs. your own compile time but...
> Also your query is looking at nagios_hoststatus table not
> nagios_hostchecks table. Please advise on this. Thanks
If shit hits the fan....
Problem acknowledged:
select * from nagios_hostchecks limit 1 offset 0\G
*************************** 1. row ***************************
hostcheck_id: 18966851
instance_id: 3
host_object_id: 6170
check_type: 0
is_raw_check: 0
current_check_attempt: 1
max_check_attempts: 2
state: 0
state_type: 1
start_time: 2009-09-22 19:41:34
start_time_usec: 229903
end_time: 2009-09-22 19:41:45
end_time_usec: 157773
command_object_id: 9766
command_args:
command_line: /opt/nagios/libexec/check_ping -H 10.xx.xx.xx
- -w 5000,100% -c 5000,100% -t 5 -p 3
timeout: 30
early_timeout: 0
execution_time: 2.01224
latency: 0.229
return_code: 0
output:
long_output:
perfdata: (null)
1 row in set (0.00 sec)
Have to go deeper into it...
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
iD8DBQFKygielI0PwfxLQjkRAkJZAJsGkCFD9Ahd/+b48yubEQTzr1Mp+wCfcH0d
2OSEglA4UTfCgP78CppV9Bs=
=W8+K
-----END PGP SIGNATURE-----
Content-Type: text/html; charset=ISO-8859-1
Hash: SHA1
          instance_id: 3
           check_type: 0
         is_raw_check: 0
                state: 0
           state_type: 1
         command_args:
              timeout: 30
        early_timeout: 0
              latency: 0.229
    &nbsp
...[email truncated]...
