Dear Sir,
You and others have done all the hard work in this matter,
On Tue, Jan 27, 2004 at 10:59:38PM -0800, Noah Leaman wrote:
> Yes. Look at that. It appears /bin/echo on OSX doesn't support -e ...
> http://developer.apple.com/documentatio ... /ManPages/
> html/echo.1.html
> So I took the -e out... but still the same problem. BUT... now knowing
> that the \t characters were probably getting interrupted. I changed the
> default delimiter to ";" and BINGO:
but it may be helpful for the NSCA developers to know whether you could
have replaced echo -e with printf.
OS-X is IIRC FreeBSD derived.
The FreeBSD 4.x man pages for printf include
STANDARDS
The printf command is expected to be compatible with the IEEE Std
1003.2
(``POSIX.2'') specification.
so since printf is POSIX compliant, if one possibly can, printf is a
better choice than echo.
printf does 'escape sequence interpolation' so
stan> printf "\t\tIn the beginning was the W\bWO\b\OR\bRD\bD.\n\n\n"
In the beginning was the WORD.
stan>
works as you expect
> noah
Yours sincerely.
Stanley Hopcroft
'...No man is an island, entire of itself; every man is a piece of the
continent, a part of the main. If a clod be washed away by the sea,
Europe is the less, as well as if a promontory were, as well as if a
manor of thy friend's or of thine own were. Any man's death diminishes
me, because I am involved in mankind; and therefore never send to know
for whom the bell tolls; it tolls for thee...'
from Meditation 17, J Donne.
