Steve Freegard wrote:
> Hi all,
> I think I've found a small bug in alpha3 (I upgraded yesterday) - if =
you
> have a service description with a '/' in it - you receive the 'It =
appears
as
> though you do not have permission to view information for this =
service..'
> message. If I take out the '/' from the description - it works fine! =
(it
> was also definatly okay before I upgraded).
There seems to be even more characters that are not perfectly =
acceptable for
the cgi programs. I found out that also the characters '\' (baskslash), =
(dot), ',' (comma) and the nordic characters ('=E4', '=F6', and '=E5') =
cause the
same problem. This problem exists at least on the "extinfo.cgi". Also =
the
"config.cgi" is not showing the nordic characters right, but this only =
a
visual problem, everything still works ok.
Tero T=F6tt=F6
Stora Enso Oyj
Anjalankoski, Finland
