On Wednesday June 4 2008 09:26:22 am Tom Sommer wrote:
> Hi,
> I have a growing pain with Nagios that I thought I might share with you.
> I have a lot (!) of servers, and while some of them are generic and thus
> grouped, I also have a lot of servers to which I need set up custom
> monitoring per host.
> This means, correct me if I am wrong, I need to go to each service I want
> to apply to a host, and enter it into the "host_name" variable.
> The problem is that the variable becomes so huge, that it becomes
> impossible to maintain effectively.
> Therefore, I suggest the opposite. Add a variable to each host (and host
> group), called "services"/"service_group", where you enter a list of
> services you want for that host. This means it becomes extremely easy to
> setup custom monitoring on a per-host basis.
> I migrated from a monitoring system that did this, and I miss it terribly.
> Thoughts?
the solution I have done here at our nagios-system is this:
Every check has its own hostgroup, a definition looks like this:
define hostgroup{
hostgroup_name mysql-check
register 0
use service-template
service_description MySQL Status
check_command check_mysql
The register 0 hides the group on the webinterface.
Now I add a host with a mysql database simply to this group, that can be do=
ne=20
per host:
use hosts-template
host_name important-server
hostgroups mysql-check
Is this something you're looking for?
Greetings,
Christian
> // Tom Sommer
> Check out the new SourceForge.net Marketplace.
> It's the best place to buy or sell services for
> just about anything Open Source.
> http://sourceforge.net/services/buy/index.php
> Nagios-devel mailing list
> [email protected]
=2D-=20
Christian Schneemann
=2D------------------------------------
SUSE LINUX Products GmbH,
Maxfeldstr. 5, D - 90409 N=FCrnberg
Phone:=A0=A0+49 (0)911 - 740 53 0
e-mail:=[email protected]
SUSE LINUX Products GmbH, GF: Markus Rex
HRB 16746 (AG N=FCrnberg)
