> -----Original Message-----
> From: [email protected]=20
> [mailto:[email protected]] On Behalf=20
> Of Ethan Galstad
> Sent: Tuesday, November 06, 2007 10:19 AM
> To: Nagios Developers List
> Subject: Re: [Nagios-devel] 3.0b6 crashes with SIGSEGV
>=20
> Boeckman, Matthew wrote:
> > Just upgraded to 3.0b6 from what was a stable 3.0b3=20
> install. Check of=20
> > the config files comes back fine, but when starting the=20
> deamon I get=20
> > after a few moments:
> >=20
> > Caught SIGSEGV, shutting down...
> >=20
> > I have debug set pretty high but do not see anything=20
> jumping out at me=20
> > from the logs as a cause (brief snippet of nagios.debug final few=20
> > lines
> > below) - is there a known issue, or anything more I can provide? I=20
> > will probably roll back to 3.0b3 shortly.
> >=20
> > -Matthew
> >=20
> > Nagios.debug:
> >=20
> > [1194366930.175483] [2048.0] [pid=3D28012] UNHANDLED MACRO=20
> #149! THIS IS=20
> > A BUG!
> > [1194366930.175499] [2048.0] [pid=3D28012] UNHANDLED MACRO=20
> #150! THIS IS=20
> > A BUG!
> > [1194366930.175512] [2048.0] [pid=3D28012] UNHANDLED MACRO=20
> #151! THIS IS=20
> > A BUG!
> > [1194366930.175526] [2048.0] [pid=3D28012] UNHANDLED MACRO=20
> #152! THIS IS=20
> > A BUG!
>=20
>=20
> Well, this is one bug.
>=20
>=20
> > [1194366930.184171] [016.2] [pid=3D28012] Moving temp check=20
> result file=20
> > '/usr/local/nagios/var/spool/check
> > results/checkZWY3uz' to queue file
> > '/usr/local/nagios/var/spool/checkresults/cRAAfPr'...
> > [1194366930.192109] [016.2] [pid=3D28011] Moving temp check=20
> result file=20
> > results/checkbx9gcH' to queue file
> > '/usr/local/nagios/var/spool/checkresults/cNf2sxz'...
> > [1194366930.424821] [008.1] [pid=3D27982] ** Event Check Loop=20
> > [1194366930.424845] [008.1] [pid=3D27982] Next High Priority=20
> Event Time:
> > Tue Nov 6 09:35:31 2007
> > [1194366930.424858] [008.1] [pid=3D27982] Next Low Priority=20
> Event Time:
> > [1194366930.424867] [008.1] [pid=3D27982] Current/Max Service =
Checks:=20
> > 7/0 [1194366930.424888] [008.2] [pid=3D27982] No events to execute =
at=20
> > the moment. Idling for a bit...
> > [1194366930.424897] [001.0] [pid=3D27982]=20
> check_for_external_commands()=20
> > [1194366930.424909] [064.1] [pid=3D27982] Making callbacks (type =
8)...
> > [1194366930.677126] [008.1] [pid=3D27982] ** Event Check Loop=20
> > [1194366930.677142] [008.1] [pid=3D27982] Next High Priority=20
> Event Time:
> > [1194366930.677154] [008.1] [pid=3D27982] Next Low Priority=20
> Event Time:
> > [1194366930.677162] [008.1] [pid=3D27982] Current/Max Service =
Checks:=20
> > 7/0 [1194366930.677172] [008.2] [pid=3D27982] No events to execute =
at=20
> > [1194366930.677181] [001.0] [pid=3D27982]=20
> > [1194366930.677191] [064.1] [pid=3D27982] Making callbacks (type =
8)...
> > [1194366930.928492] [008.1] [pid=3D27982] ** Event Check Loop=20
> > [1194366930.928509] [008.1] [pid=3D27982] Next High Priority=20
> Event Time:
> > [1194366930.928521] [008.1] [pid=3D27982] Next Low Priority=20
> Event Time:
> > [1194366930.928530] [008.1] [pid=3D27982] Current/Max Service =
Checks:=20
> > 7/0 [1194366930.928540] [008.2] [pid=3D27982] No events to execute =
at=20
> > [1194366930.928548] [001.0] [pid=3D27982]=20
> > [1194366930.928559] [064.1] [pid=3D27982] Making callbacks (type =
8)...
> > [1194366931.179900] [008.1] [pid=3D27982] ** Event Check Loop=20
> > [1194366931.179941] [008.1] [pid=3D27982] Next High Priority=20
> Event Time:
> > [1194366931.179954] [008.1] [pid=3D27982] Next Low Priority=20
> Event Time:
> > [1194366931.179963] [008.1] [pid=3
...[email truncated]...
