On 01/10/2013 05:22 PM, Adam James wrote:
> Hi Andreas,
> On 08/01/13 10:12, Andreas Ericsson wrote:
>> lib/runcmd.c is the library code which shouldn't change its behaviour. The
>> code in utils.c should be removed instead.
> The attached patch removes the general escape handling code from
> utils.c, with the exception of "\!" as otherwise it wouldn't be possible
> to include a "!" inside an argument.
> If you think this should be done differently then let me know and I'll
> amend the patch.
>> On the other hand, the runcmd.c code should have a flag argument one can
>> use to tell it to ignore certain characters, with "ignore everything" to
>> be taken as "split on every whitespace-sequence and disregard quoting and
>> escaping entirely".
> What's the use case for this?
To run commands via execve() and let the executed command see exactly what
we want to pass to it. It would be a pretty simple thing to do and would
allow callers to either handle their own escaping or ignore it entirely.
OP5 AB www.op5.se
on peace.
