Re: [Nagios-devel] patch for preprocessing macros
> Thanks for the patch Matthias. Its a few months old, but I kept it on
> my TODO list. I think I'll reimplement the patch as a recursive
> function that allows multiple levels of nesting. Not sure if multiple
> levels are absolutely necessary, but the functionality will be there if
> someone needs it.
Hi Ethan,
thanks for your reply, I didn't expect an answer any more :)
I couldn't see need for recursion that time. To be honest, I can't see
any need for the entire patch any more, since the hostname is not
mandatory in 3.x any more - And I think this is the main purpose for
functionality like that.
Maybe such a solution could make sense in combination with custom macros.
Thus it's up to you, but thanks again for your reply.
Matthias
