Re: [Nagios-devel] Nagios sometimes shows wrong status
sorry, here is the right snippet from nagios.log:
[1243412547] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412545
[1243412553] SERVICE ALERT: acgweb1;BASIC_SVM;OK;SOFT;3;CRITICAL - One or
more disks are in maintenance state.
[1243412558] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412556
[1243412565] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412563
[1243412579] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412577
[1243412583] SERVICE ALERT: acgweb1;BASIC_SVM;CRITICAL;SOFT;1;CRITICAL -
One or more disks are in maintenance state.
[1243412590] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412588
[1243412593] SERVICE ALERT: acgweb1;BASIC_SVM;OK;SOFT;2;CRITICAL - One or
[1243412625] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412623
[1243412828] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412826
[1243412838] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412836
[1243412854] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412851
[1243412869] EXTERNAL COMMAND:
SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243412866
[1243412875] EXTERNAL COMMAND:
[1243413483] SERVICE ALERT: acgweb1;BASIC_SVM;CRITICAL;SOFT;1;CRITICAL -
[1243413603] SERVICE ALERT: acgweb1;BASIC_SVM;OK;SOFT;2;CRITICAL - One or
[1243413903] SERVICE ALERT: acgweb1;BASIC_SVM;CRITICAL;SOFT;1;CRITICAL -
and the time of the two systems are sync :-)
# date && ssh acgweb1 date
Wednesday, May 27, 2009 2:02:20 PM GMT
Wed May 27 14:02:20 GMT 2009
regards,
michael
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 27/05/09 04:52 AM, Michael Prochaska wrote:
>> Hi!
>> I've seen a strange behavior of nagios with a very simple check script.
>> the relevant part of the script:
>> MAINTCNT="`/usr/sbin/metastat |grep -i maint |wc -l`"
>> RESYNCNT="`/usr/sbin/metastat |grep -i resync |wc -l`"
>> NOTOK=0
>> status=$STATE_UNKNOWN
>> if [ $RESYNCNT -gt 0 ]; then
>> NOTOK=1
>> TEXT="WARNING - One or more disks are in resync state. "
>> status=$STATE_WARNING
>> fi
>> if [ $MAINTCNT -gt 0 ]; then
>> NOTOK=1
>> TEXT="CRITICAL - One or more disks are in maintenance state."
>> status=$STATE_CRITICAL
>> fi
>> if [ $NOTOK -eq 1 ]; then
>> echo $TEXT
>> datum=`date`
>> echo $datum $status >> /tmp/svm.debug
>> exit $status
>> fi
>> echo "OK - There is no maintenance necessary!"
>> exit $STATE_OK
>> when executing the script from command line, the return code always is 2
>> and the output always is "CRITICAL - One or more disks are in
>> maintenance
>> state." (because there is one dead disk) => thats ok
>> when nagios executes the script, the output always is "CRITICAL - One or
>> more disks are in maintenance state." but the return code sometimes is 0
>> and sometimes is 2 => thats not good
>> [1243410051] SERVICE ALERT: acgweb1;BASIC_SVM;CRITICAL;SOFT;1;CRITICAL -
>> [1243410063] EXTERNAL COMMAND:
>> SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243410061
>> [1243410071] SERVICE ALERT: acgweb1;BASIC_SVM;OK;SOFT;2;CRITICAL - One
>> or
>> [1243410083] EXTERNAL COMMAND:
>> SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243410081
>> [1243410091] SERVICE ALERT: acgweb1;BASIC_SVM;CRITICAL;SOFT;1;CRITICAL -
>> [1243410124] EXTERNAL COMMAND:
>> SCHEDULE_SVC_CHECK;acgweb1;BASIC_SVM;1243410122
>> [1243410131] SERVICE ALERT: acgweb1;BASIC_SVM;OK;SOFT;2;CRITICAL - One
>> or
>> [1243411031] SERVICE ALERT: acgweb1;BASIC_
...[email truncated]...
