Re: [Nagios-devel] Nagios 4: Registering object relationships in
On 14 Jan 2013, at 09:35, Ton Voon wrote:
>=20
> On 8 Jan 2013, at 10:16, Andreas Ericsson wrote:
>=20
>> On 01/08/2013 10:24 AM, Ton Voon wrote:
>>> My original patch, reattached, is not ideal but fixes the problem, =
so I present it as a way to show why the current behaviour is wrong. I'm =
sure there's a better solution, probably some other "do expansion of =
object relationships" call that should be invoked instead, but I can't =
quite understand the C-fu magic that is going on with the new =
configuration code!
>>>=20
>>=20
>> Thanks a lot. I'll get this fixed today.
>=20
> Have you had a chance to look at this? Alternatively, can you provide =
some pointers to where this might be and what to look out for?
Hi Andreas,
You're probably very busy, but can you provide some pointers for where =
to look please? There's some black magic going on which I can't decode!
In the other thread, the hint:
> create_object_table(), called from the mktable() macro. Both live in
> common/objects.c.
was enough to get me on the right track. I think there's something =
similar here required for me to grok the expansion logic.
Ton
