Re: [Nagios-devel] Problem with NSCA large and multiline output
>>If possible I am using ssh instead of nsca and nrpe. So I did not have
>>this limit.
Thats ok! But when you use distributed monitoring, then is ssh or nrpe no =
solution ;-)! I hope Ethan can fix this problem!
Bye
Michael
-----Urspr=FCngliche Nachricht-----
Von: Nagios Developers List
Gesendet: 09.01.08 10:05:02
An: Nagios Developers List
Betreff: Re: [Nagios-devel] Problem with NSCA large and multiline output
Ups ;-) Of course your right.
this limit.
Cheers
Gerd
Am Dienstag, den 08.01.2008, 16:39 +0100 schrieb Michael L=FCbben:
> Hi Gerd,
> nrpe 2.10 and higher supports multiline output ;-)
>=20
> bye
> Michael
>=20
> Gesendet: 08.01.08 12:58:50
> Betreff: Re: [Nagios-devel] Problem with NSCA large and multiline output=
>=20
>=20
> Hi Michael,
>=20
> believing the changelog of Nagios max plugin output length is now 8kb.
> And Right now NSCA and NRPE aren't able to handle more than 1
> line. :-( =20
>=20
> Cheers,
>=20
> Gerd
> Am Freitag, den 04.01.2008, 14:36 +0100 schrieb Michael L=FCbben:
> > Hi @all,
> >=20
> > i use distributed monitoring! Now i will update to the Version 3! But =
the nsca send not the complet plugin output! Now i have change the MAX=5FPLU=
GINOUTPUT=5FLENGTH from 512 to 2512 and new compiled. The nsca send now more=
output, but not enough. Has someone an idea which maximal value i can use=
=3F Another problem is that the nsca can only send the first line, not more!=
I am not a c developer and have no idea how to fix this.
> >=20
> > Bye
> > Michael
> > =5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
=5F=5F=5F
> > In 5 Schritten zur eigenen Homepage. Jetzt Domain sichern und gestalte=
n!=20
> > Nur 3,99 EUR/Monat! http://www.maildomain.web.de/=3Fmc=3D021114
> >=20
> >=20
> > This SF.net email is sponsored by: Microsoft
> > Defy all challenges. Microsoft(R) Visual Studio 2005.
> > http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
--=20
Gerd Mueller =20
Senior Consultant
NETWAYS GmbH | Deutschherrnstr. 47a | D-90429 N=FCrnberg=20
Tel: +49 911 92885-0 | Fax: +49 911 92885-33=20
GF: Julian Hein | AG N=FCrnberg HRB18461=20
=20
http://www.netways.de | [email protected]=20
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239 ... marketpla=
ce
[email protected]
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F
Jetzt neu! Sch=FCtzen Sie Ihren PC mit McAfee und WEB.DE. 30 Tage
kostenlos testen. http://www.pc-sicherheit.web.de/startse ... c=3D022220
