Re: [Nagios-devel] Nagios navbar search enhancement (Was: Questions
On 2013-06-04 15:43, Jonas Meurer wrote:
> Hey,
> I just prepared a patch against git master (commit 758a64). I hope that
> it helps. Don't hesitate to ask if you've any questions.
> Also feel free to rename the config options if you don't like the names.
> The patch is attached.
Applied. Thanks.
I made the new options default to ON in the code and renamed them
"navbar_search_addresses" and "navbar_search_aliases" instead od the
"navbar_search_for..." since we're actually searching for hosts by
searching the hosts' configured properties.
OP5 AB www.op5.se
on peace.
