Hash: SHA1
Yann JOUANIN wrote:
| Hello Everyone,
| I started a week ago to dev a CGI which permit to export Nagios Status
| in JSON format, it helps to create graphic interface (web or not).
| You can find this CGI on http://www.yannj.fr
| I am looking for people to test it. This is a alpha development at this
| time and all info are sent for the moment without filter, but it runs!
| I also coded a php class to help in using the format on the client side,
| and I also coded a NagVis backend, with this CGI, this is not compulsory
| to use NDO2DB to get status etc from Nagios.
| Don’t hesitate to contact me for any question, suggestion or other!
That seems like good stuff, and a promising way to quickly set-up a PHP
web interface without the burden of NDODB (BTW I'm not saying NDODB
should be dropped; any web interface could have different backends but
not every installation require NDODB).
I'm wondering how hard it would be to make this an event broker instead
(you can fetch the file for remote frontends), or even better a
configure option replacing USE_XSDDEFAULT (would allow changing the
format of the status file without breaking the CGI, making place for
concurrent JSON-based interfaces).
I'd be glad to know what others think about this... Would it make sense
to include this in a future release?
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFIUpDH6dZ+Kt5BchYRAu3tAKCzmET3iQb1kcqLsQg9dzZYRYiHsQCdGM9g
Hn5NHt4AR2KtPsPpsXlOBzo=
=FDOL
-----END PGP SIGNATURE-----
