> Christian Schneemann schrieb:
> > On Thursday February 14 2008 10:53:26 am Hendrik B=E4cker wrote:
> >>> (no debugging symbols found)
> >> Please try again with a modified makefile.
> >> You need to 'enable' the CFLAGS used for valgrind in base/Makefile and
> >> re-compile the binary.
> >> After that try to run nagios against the binary in base/nagios or do a
> >> make install-unstripped
> >> That should include debug information to the binary and the gdb should
> >> be more verbose.
> > It seems that nagios is compiled with all debug options.
> If this would be true the 'bt' should print out some linenumbers
Ok, I've resolved the first problem: reading your mail
It was not enabled, I've enabled it now but now it does not compile anymore=
=2E=20
To compile it I had to diesable the embedded perl.
And now the segfault is gone.
I think I have to play around to find the error. A colleague meant that it=
=20
could be a locking problem and this can be gone now because of the change i=
n=20
the binaries.=20
> Hendrik
=2D-=20
=2D------------------------------------
SUSE LINUX Products GmbH,
Maxfeldstr. 5, D - 90409 N=FCrnberg
Phone:=A0=A0+49 (0)911 - 740 53 0
e-mail:=[email protected]
SUSE LINUX Products GmbH, GF: Markus Rex
HRB 16746 (AG N=FCrnberg)
