Re: [Nagios-devel] Significant NRPE rework, including IPv6
On 12 Mar 2011, at 13:20, Kristian Lyngst=F8l wrote:
> I've started working on making NRPE somewhat maintainable, as it's a
> bit of a mess in its current state.
>=20
> The original goal was adding IPv6-support, which I've done, but it has
> escalated somewhat after that.
>=20
> I've since:
>=20
> - Transitioned to autotools/autoconf for a somewhat more convenient
> build system
> - ... Introduced system-wide header files (...)
> - Started sorting out what's local and global, removing redundant
> prototypes and declaring functions static
> - Imported a couple of patches kept by Debian that were reasonable.
> - Re-indented the code (Normally I wouldn't do this on a project
> that's not mine, but I wasn't able to wrap my head around the style as
> it was -- too far off)
> - Removed several redundant comments (Stuff like "/* wait for
> connections */ wait_for_connections();" which only serves as noise)
> - Removed unused or unneeded code.
> - Misc other
>=20
> While the IPv6-support is fairly complete (using getaddrinfo()), the
> nrpe-server needs two more features to be release-ready: Listening to
> both ipv4 and ipv6 at the same time, and ipv6-awareness in
> allowed_hosts. This is on my todo-list. I also expect I've broken the
> build on certain platforms, and I intend to test this to some degree.
>=20
> The work can be found at: https://github.com/KristianLyng/nrpe
>=20
> I do not want to maintain a fork, thus I'm interested to co-operate to
> get this "upstream". Since the code looked almost abandoned, I decided
> that it would be best to adapt a "fix first, ask later"-approach.
>=20
> I've so far dubbed it NRPE "3.0", and I'm using it both nrpe-server
> and check_nrpe on several servers.
>=20
> Any and all feedback is much welcomed.
Kristian,
If you could incorporate this enhancement, that would be great:=20
http://labs.opsview.com/2008/08/enhanci ... ge-output/
We return a "version 3" in the packet data.
I would like this to get back upstream too, but I don't have commit =
access to the NRPE areas.
Ton
