Alessandro Ren wrote:
> I have a similiar problems with nagios 3 and 3rc3, could not locate
> yet why this happens.
> []s.
> Christoph Maser wrote:
>> Hi list
>> we are testing nagios3 and since the release of the final version we
>> encountered a massive problem. Once a day nagios stops working
>> correctly. Log file ist full of:
>> [$timesatmp] Warning: The check of service '$SERVICE' on host '$HOST'
>> could not be performed due to a fork() error. The check will be
>> rescheduled.
>> After a restart of nagios everything works fine again. I have checked
>> the checkresult-spool-dir and found tons of _old_ files. When the
>> problem occurs nagios has open 1024 FHs most of them (> 1000) for
>> checkresult files. Of course 1024 is the open files limit for my nagios
>> user.
>> This problem occurs every day and it started exactly with the install of
>> 3.0 final. We where running 3.0rc3 before and did not have any problems.
>> When i look at the process from time to time i do not see a list of FHs
>> building up slowly so i assume that there is some "event" which is
>> trigging this malfunction.
>> Chris
Is anyone else encountering this error? I'm not seeing anything obvious
in the diffs that would have caused this problem post 3.0rc3.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
