I have snooped a little bit around and seems like I have SSL issue as I am seeing this in my /var/log/messages on clients side.
Error: Could not complete SSL handshake
I am confused a little bit why because check_nrpe returns plugin version as expected.
./check_nrpe -H testserv
NRPE v2.14
Any ideas?
Return code of 255 is out of bounds
Re: Return code of 255 is out of bounds
Are you only seeing this error in the web interface? As in, can you manually run the command line equivalent to the service check you are seeing this error on and it returns the proper output?
What would be command equivalent?slansing wrote:Are you only seeing this error in the web interface? As in, can you manually run the command line equivalent to the service check you are seeing this error on and it returns the proper output?
If you post a copy of your service configuration file I can translate it for you and explain how to do it if you need to again "its a useful task to know." Lets move this to your other thread, I'll lock this one up for now as you have the same question there. See you in http://support.nagios.com/forum/viewtop ... =7&t=21462 !
