I setup the centos vm on my personal system, just to get familiar with the install. Worked great!
Next I installed the centos vm images on a larger machine in prep for future use and now when I hit the site for the first time, I do not get the install wizard instead it only prompted for the username and password, which I do not have. I have been trying to update files that I am aware of but cannot get passed the login screen.
Is there something I can blank out to make this work? or force the install.php to happen.
Ray
nagios centos vm image setup problem
Re: nagios centos vm image setup problem
By default it is:
UN: nagiosadmin
PWD: nagiosxi
UN: nagiosadmin
PWD: nagiosxi
right, that did not work, but the reset_nagiosadmin_password.php script worked great.
Excellent! Please feel free to contact us again if you have any additional questions or issues.
Thanks!
Thanks!
