warning and critical if less than
lukecolb
Post by lukecolb »
Hi
I've not been able to work out or find how to do this.
Does anyone know how you set you warning levels to be warning if less than say ten and critical if less than 5
Luke
Re: waring and critical if less than
Post by slansing »
Can you share this example in a plugin you are using?
lukecolb
Re: warning and critical if less than
Post by lukecolb »
The command is
# 'snmp_ups_voltage_in' command definition
command_name snmp_ups_voltage_in
command_line $USER1$/check_snmp -H $HOSTADDRESS$ -C $ARG1$ -o .1.3.6.1.4.1.318.1.1.1.3.2.1.0 -l '\Input Voltage\' -u '\Volts\'
I would want it to go critical if it is below 220
Post by slansing »
If the plugin itself does not support the ability to reverse this, then you can not do that. Have you looked at check_snmp's usage? To do so run:
/usr/local/nagios/libexec/check_snmp -h
lukecolb
Post by lukecolb »
Oh cool that was simple adding : to -c220 to make it -c220: reverses it
EDIT: slansing beat me to it, but here's an alternative that may work if a plugin does not support it natively:
You could also use the Negate plugin to turn a CRITICAL into an OK and vice versa
http://assets.nagios.com/downloads/nagi ... Plugin.pdf
lukecolb
Post by lukecolb »
Cool i may have to use that elsewhere
Sounds good. Let us know if you have any more questions.
