Passive check requirement.
sujitt
Post by sujitt »
I have a new requirement to be implemented in nagios XI. I am looking for IDeas which i could pursue to get to a solution.
1. This is for a Unix host . where a command on error needs to report back to NAgios of an error ( I suppose this part is easy with nsca_send etc.)
2. The output which the NSCA_Send sends back should contain contextual information which will be a command line script which will be used for restarting that process.
3. The commandline which was sent by the nsca_send should be available for an administrator to manually run through nagios so that security creds are utilized.
my original thought was to send the comandline as an output of the command execution which will be available as Serviceoutput macro .
How can I make the event handler not execute immediately but be available for an administrator to execute?
Are there any other ways to implement this in Nagios XI.?
Re: Passive check requirement.
I would use the builtin Actions component to add a quick action to execute the command
http://assets.nagios.com/downloads/nagi ... ponent.pdf
Changes are made in Admin -> Manage Components -> Actions -> Settings
