http://assets.nagios.com/downloads/nagi ... entLog.pdf
We followed instructions from the link above to monitor Windows Event Logs for Errors and notify us once Errors are found using NagEventLog addon. NSCA is configured on NagiosXI server. It is working for us so far. At the same time, we are seeing this error on client machines:
The description for Event ID 0 from source NagiosEventLog cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Error (0): Server closed connection before init packet was received
We Removed only_from line from /etc/xinetd.d/nsca file, and it does not stop these errors neither.
My question are:
1. do you have any things that can help me stop these errors and monitor windows event logs errors as well?
2. Is there any other method i can use to monitor Windows Event Log?
Re: monitor windows event logs errors
Closing this thread as this question is being asked by you elsewhere.
