Cant able to get graph
siriideepak
In my nagiosxi no graphs are there.When i run the command LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok it shows the following error.
Regards,
Deepak.P
Regards,
Deepak.P
Re: Cant able to get graph
Did you try to upgrade the rrdtool to version 1.4.4 before running into this issue? I believe the version of rrdtool that is inluded by default in XI is 1.3.8.
siriideepak
Cant able to upgrade rrdtool from 1.3.8 to 1.4.4 in rhel 6 any solution for this and how to upgrade.
Regards,
Deepak.P
Regards,
Deepak.P
Technically, you need to downgrade. What repos are you currently using?siriideepak wrote:Cant able to upgrade rrdtool from 1.3.8 to 1.4.4 in rhel 6 any solution for this and how to upgrade.
yum repolistFormer Nagios employee
siriideepak
Please find the attached screenshot for yum repolist.
Regards,
Deepak.P
Regards,
Deepak.P
It appears as though you have not registered this RHEL installation with the subscription manager, you will need to do this to be able to reach the repo's we require. Also, there are some additional REPO's listed there, do you have in house repo's that have versions of packages above ours?
Lets see what version of RRD tool you are using:
If it is greater than 1.3.8 you will want to downgrade it -
You can try downgrading the rrd version via the following command:
yum list installed | grep rrd
yum downgrade rrdtool-
siriideepak
Please find the attached screenshot for yum list installed | grep rrd.
Regards,
Deepak.P
Regards,
Deepak.P
You cannot use the required repos because your version of redhat has not been registered . . . . Please do so . . .
Or use centos instead . . . .
siriideepak
I registered with rhel still the same.
Regards,
Deepak.P
Regards,
Deepak.P
I beg to differ, the downgrade looks like it worked as you now have the older version of rrdtool.siriideepak wrote:still the same.
Can you rerun:
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.okEDIT: I stand corrected, you may have two different versions of rrdtool, or mismatched versions of the perl and python rrdtool packages. Try:
yum install rrdtool-perl rrdtool-python
