Performance Data Tool now available
Post by Box293 »
Hello fellow Nagios XI users. I have created a Component called the Performance Data Tool that is available for download from the Nagios Exchange.
The purpose of the Performance Data Tool is to give you the ability to view and manipulate the .rrd and .xml performance data files on your Nagios XI host.
This can be helpful for:
  • Viewing graphs for services that have been disabled
    • Because they are disabled you can no longer access the graphs to refer to the historical performance data.
    Viewing RRD files in a table format
    • Can be easier to browse data compared to looking at graphs
    Merging RRD files
    • If you rename a host/service the performance data can be merged into the new RRD files
    • After a Nagios host rebuild, the old performance data can restored and then merged into the new RRD files on the rebuild Nagios host
    Deleting performance data
    • Cleaning up old RRD and XML files that were left behind when a host/service was decommissioned
Version History:
2013-10-11
Initial release
Current features not yet implemented:
  • Viewing graphs
    Merging an entire folder / subfolder of RRD files
2013-11-10
Added functionality to merge an entire folder / subfolder of RRD files
Fixed a couple of bugs
Some minor improvements
Any questions / suggestions / requests are always welcome.
Re: Performance Data Tool now available
Post by slansing »
Awesome Work Box! I'm going to be testing this out some time this week... when I get enough time. I'll share some feedback as well! :)
