NagiosXI in 32bit CentOS to 64bit
justine
Post by justine »
Hi! I have NagiosXI that is installed in CentOS 5.7 i386. I'm planning to move my Nagios to a different machine because of its hardware performance. Will I have difficulty moving it to CentOS 5.9 64bit? Any recommendations?
lcontreras
Re: NagiosXI in 32bit CentOS to 64bit
Post by lcontreras »
Hi justine,
You shouldn't have any problem on moving your XI to another server arch.
abrist
Red Shirt
Post by abrist »
It should relatively painless. The only potential issue is related to the migration of performance data as rrds are binaries and must be rebuilt for the new arch. Make sure you have *at least* 3x as much free disk space as used disk space for the perfdata migration:
http://support.nagios.com/wiki/index.ph ... Install.3F
justine
Post by justine »
Thank you all! I have successfully migrated nagiosxi to the new arch.
Post by slansing »
Great! Let us know if you have any issues!
