I'm having a strange problem with the results of an SQL service check which does not seem to be consistent with the rest of the SQL checks in the system.
I have checked 2 different service checks from the command line to troubleshoot but no issue:
[root@aunagiosxi libexec]# ./check_mssql -H X --port 1433 --username X --password "X" --database X --query "EXECUTE usp_Alert_ConsignmentDataNotPopulating" --result 0
OK: Query results matched, query duration=1.943026 seconds.
[root@aunagiosxi libexec]# ./check_mssql -H X --port X --username X --password "X" --database LDW_Staging --query "EXECUTE usp_Alert_JobEventDataNotPopulating" --result 0
OK: Query results matched, query duration=0.000855 seconds.
Yet when I run from Nagios console I get 2 different results:
MSSQL Query - Check TMS to AUVIS Sync
This service is flapping
Warning 5m 45s 5/5 15/10/2013 16:50:13
WARNING: Query results matched, query duration=2.007195 seconds.
MSSQL Query - Check TMS to LDW Sync
Ok 10d 16h 3m 52s 1/5 15/10/2013 16:50:29
OK: Query results matched, query duration=0.000984 seconds.
Some time ago I updated the code within the script which caused a bug in the results translation to OK/Warning/Alert. But I now only get an issue with this one particular result. See below forum post:
http://support.nagios.com/forum/viewtop ... 16&t=10266
Do you have any idea what I can do to rectify/further analyse this please?
Issues with MS SQL checks
Re: Issues with MS SQL checks
Just an update, I have just ran the same query 4 times from the command line and got differing results:
WARNING: Query results matched, query duration=2.010876 seconds.
WARNING: Query results matched, query duration=2.027159 seconds.
OK: Query results matched, query duration=1.987831 seconds.
WARNING: Query results matched, query duration=2.010377 seconds.
I have also checked the script: /usr/local/nagios/libexec/check_mssql and the changes that I was advised to make are still saved within the syntax.
If you do not specify a warning threshold a default of 2 seconds is used
/usr/local/nagios/libexec/check_mssql -h
check_mssql, 0.6.9
Copyright (c) 2008 Gary Danko ([email protected])
2012 Nicholas Scott ([email protected])
This plugin checks various aspect of an MSSQL server. It will also
execute queries or stored procedures and return results based on
query execution times and expected query results.
Options:
-h, --help
Print detailed help screen.
-V, --version
Print version information.
-H, --hostname
Hostname of the MSSQL server.
-U, --username
Username to use when logging into the MSSQL server.
-P, --password
Password to use when logging into the MSSQL server.
-p, --port
Optional MSSQL server port. (Default is 1433).
-I, --instance
Optional MSSQL Instance
-d, --database
Optional DB name to connect to.
-q, --query
Optional query or SQL file to execute against the MSSQL server.
-s, --storedproc
Optional stored procedure to execute against the MSSQL server.
-r, --result
Expected result from the specified query, requires -q. The query
pulls only the first row for comparison, so you should limit
yourself to small, simple queries.
-w, --warning
Warning threshold in seconds on duration of check (Default is 2).
Accepts decimal values, note however that there must be at least a
leading 0. Example, .0023 is not a valid entry, but 0.0023 is.
-c, --critical
Critical threshold in seconds on duration of check (Default is 5).
-W, --querywarning
Warning threshold for the query IF IT IS NUMERIC, otherwise, this
will be ignored.
-C, --querycritical
Critical threshold for the query IF IT IS NUMERIC, otherwise, this
will be ignored.
Example: check_mssql -H myserver -U myuser -P mypass -q /tmp/query.sql -w 2 -c 5
Example: check_mssql -H myserver -U myuser -P mypass -q "select count(*) from mytable" -r "632" -w 2 -c 5
Send any questions regarding this utility to [email protected] or [email protected].
Sorry, my bad for not working this out. I've updated and now working OK.
A warning alert with a return of "Query results matched" made me think it was something else. Maybe a return of "Warning - Query time-out occurred" would be more specific!
Ah! Okay, we will close this for now.
