check_snmp
diegosiassb
check_snmp
Post by diegosiassb »
Hy,
I have the following problem with my version nagiosxi Nagios XI 2012R2.4.
Using a command line runs the following query:
[root@nagiosxi2 libexec]#
. / check_snmp-10.102.38.176-H or-C .1.3.6.1.4.1.2021.8.1.101.1 sianagios-s "\" carte_geccarte_lnxcarte_Sepacarte_Operation "\"
SNMP OK - "carte_geccarte_lnxcarte_Sepacarte_Operation" |
If I plug it into the gui does not work.
I attach the configuration. (files)
thanks
Diego
diegosiassb
Re: check_snmp
I enclose error
Diego
abrist
Red Shirt
Re: check_snmp
Post by abrist »
Does the check work on the details page? There are some known issues with the "test check command" option and escaping.
diegosiassb
Re: check_snmp
No it does not work. The problem is the syntax for me.
There are special rules?
is like working in the shell? I do not think?
thanks
yancy
Re: check_snmp
Post by yancy »
diegosiassb,
What is the OID you are trying to use? It should not start with a dot.
-Yancy
