Is there any way to know the result of a plugin is handled by Nagios?
Running the plugin manual line in shell runs well and I've been to see the " Final output:" on nagios.debug to verify if it is fine with commands.cfg. The problem is that the state is pending forever as if the plugin had not executed or returned nothing.
In nagios.log see "Warning: Check status contained service 'Tempo de ligação' on host 'serversms', but the service could not be found! Ignoring check."
Nagios plugin(check_mssql_health) problem
Re: Nagios plugin(check_mssql_health) problem
What is the full command that your are running?
