The above image is a drawing of my current environment. The only thing not current is the fusion server is not yet installed/built. I'm going this way, in the hopes after my many chats at the conference, that fusion will finally get the ability to keep you logged in as yourself when drilling down
Anyway, on to the advice I need.....
1.) Does this look like a good layout? Each square represents either a physical data center or a firewalled data center.
2.) There are a couple servers on one of the firewalled XI boxes that I would like to have showing in the large data center's XI server. I can send information from one XI to another, correct? Can you believe I never did that yet
Or.....should I just install the gearman worker like it says is on the one XI server and push those couple checks over to it from the main XI box?
3.) Umm, I know there was something else, but it's been a long week already and it is only Tuesday morning!
