Run netstat using NRPE failed
yanivhs
Post by yanivhs »
Hello
I've created a simple script to check established connection number.
The script runs fine, but when I'm trying to run it using NRPE, I'm getting "OK, 0 connections " instead of the real connection number.
I've added the sudo to the command configuration in nrpe.cgf, and now I'm getting "sh: /usr/bin/sudo: Permission denied"
What I'm doing wrong?
Both systems are centos 6.4 and the nagios version is 4
Re: Run netstat using NRPE failed
Post by slansing »
Can you share your script with us so we can see what may be causing this? Without that we can only guess.
You should not need sudo for the nrpe.cfg it's read by the nagios user and the permissions on it should reflect that.
yanivhs
Post by yanivhs »
Here are the scripts
nrpe.cfg
My script ( located at /usr/lib64/nagios/plugins )
I've also tried copying the netstat file to the plugins directory, but with same results.
Yaniv
check_netstat.sh.txt
(751 Bytes) Downloaded 631 times
nrpe.cpg.txt
(8.11 KiB) Downloaded 634 times
Your script is wrong. Try the one I attached.
Also, what is the check command you are actually executing from Nagios?
(722 Bytes) Downloaded 694 times
yanivhs
Post by yanivhs »
Running the attached one I'm getting :
/usr/lib64/nagios/plugins/check_netstat.sh: line 22: su: command not found
/usr/lib64/nagios/plugins/check_netstat.sh: line 24: [: -lt: unary operator expected
/usr/lib64/nagios/plugins/check_netstat.sh: line 33: [: -gt: unary operator expected
/usr/lib64/nagios/plugins/check_netstat.sh: line 42: [: -gt: unary operator expected
From the nagios server I'm executing "check_nrpe -H 10.4.4.30 -c check_netstat 32 64" ( from the terminal )
abrist
Red Shirt
Post by abrist »
[email protected] wrote:/usr/lib64/nagios/plugins/check_netstat.sh: line 22: su: command not found
Do you have 'su'?
which su
yanivhs
Post by yanivhs »
Yes, I have su
/bin/su
Permissions :
-rwsr-xr-x. 1 root root 34904 May 23 14:00 /bin/su
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Is /bin/bash actually a bash shell or linked to another shell? It seems that it does not contain standard operators that bash should. You might hard code su to /bin/su on line 21 and see if that resolves not finding it.
yanivhs
Post by yanivhs »
Tried that, but I'm getting a permission denied
/bin/su: Permission denied
sreinhardt
Out of curiosity, do you have selinux enabled or any other restrictive security systems? Unless you have got some very strange permissions setup, I have never heard of su and sudo being inaccessible to a user. They certainly may not allow elevated rights if the user does not have permission, but thats far from being denied read\execute permission.
