Escaping " issue
BanditBBS
Escaping " issue
Post by BanditBBS »
Ok, so I can run this from command line:
./check_snmp -H 10.6.59.90 -o SNMPv2-SMI::enterprises.5528.100.4.2.10.1.7.303280526 -C xxxxxx -P 2c -l "Spot Leak" -s "\"No Leak\""
And I get this back:
Spot Leak OK - "No Leak" |
But when I put that in $ARG1$ using check_snmp command, it screws up the -s part. The string actually contains double quotes. How can I put that in XI so it performs the command properly?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
-fno-stack-protector
Re: Escaping " issue
Post by sreinhardt »
First question, although I figured you checked this already, you're not testing this with the test command button right?
Otherwise some options I might try:
./check_snmp -H 10.6.59.90 -o SNMPv2-SMI::enterprises.5528.100.4.2.10.1.7.303280526 -C xxxxxx -P 2c -l "Spot Leak" -s \"\"No Leak\"\"
./check_snmp -H 10.6.59.90 -o SNMPv2-SMI::enterprises.5528.100.4.2.10.1.7.303280526 -C xxxxxx -P 2c -l "Spot Leak" -s "\\"No Leak\\""
./check_snmp -H 10.6.59.90 -o SNMPv2-SMI::enterprises.5528.100.4.2.10.1.7.303280526 -C xxxxxx -P 2c -l "Spot Leak" -s \\"\\"No Leak\\"\\"
BanditBBS
Post by BanditBBS »
I was using the test command. it works fine, disregard this entire thread :(
I knew test command feature had the issue it had to run as apache not as nagios, but didn't realize there was an issue with escaping.
abrist
Red Shirt
Post by abrist »
Yep. user restriction, escaping restrictions, you name it. The test check command is really only good for those simple 'vanilla' checks. I will send this thread down the green mile . . .
