Accessing NagVis direct via URL
Fred Kroeger
I would like to access the NagVis maps directly without having to login to Nagios first - eg: URL Links in a portal to display each map.
I was thinking that I create a cname for the Nagios server and connect via that cname and authenticate as the guest user automatically.
To do this requires some entries in the htppd conf file for nagvis but I just have not been able to get it working correctly for the existing nagios server and also connecting via the cname. Is anyone able to point me in the right direction?
regards... Fred
regards... Fred
Re: Accessing NagVis direct via URL
What changes have you made? Can you link the tutorial that you used?
Fred Kroeger
I found this reference.
http://www.monitoring-portal.org/wbb/in ... tID=132884
If you follow down the thread, someone did what I am trying to do with Virtual Hosts.
It should connect automatically as the guest user if you access it via the Virtual Host address.
Any other connections via the Nagios server address will still result in a login prompt.
This is their nagvis.conf file
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www/
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
Alias /nagvis "/var/www/nagvis/share"
<Directory "/var/www/nagvis/">
AuthName "NagVis Administration"
AuthType Basic
AuthUserFile /etc/apache2/htpasswd.users
Require valid-user
AllowOverride None
</Directory>
</VirtualHost>
<VirtualHost *:80>
ServerName nagvis.domain1.de
<Directory />
AllowOverride None
</Directory>
AllowOverride All
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
SetEnv REMOTE_USER gast
RequestHeader set Cookie "nagvis_session=1"
</VirtualHost>
What version of apache are you using (there are some syntax differences between versions)?
$(which httpd) -vFormer Nagios employee
Fred Kroeger
It's the standard CentOS 6.3 VM build from Nagios
Server version: Apache/2.2.15 (Unix)
Server built: Feb 13 2012 22:31:42
Autologin in NagVis is not a very good idea but if you need to do this, you can follow the steps outlined in this post:
http://support.nagios.com/forum/viewtop ... vis#p46978
Hope this helps.
Hope this helps.
Fred Kroeger
Sorry for the delay - I posted a reply to this some time ago and just discovered it was never added?
Anyway - I only want to auto login as Guest user when Nagvis is accessed directly via the CNAME .
All other access is via the Nagios server address which should prompt for a login.
So in effect I want one URL to autologin as guest and another URL to work as it does now.
Regards.. Fred
Regards.. Fred
Fred, are we dealing with this issue in the ticketing system?
Fred Kroeger
Only via this forum that I'm aware of?
Alright, this is working on my test box. You will need to replace the ServerNames: "nagiosxi.localdomain" and "nagiosxinagvis.localdomain" with your two different dns names. One will autologin to nagvis as guest, while the other will prompt with a username/password for nagvis. This still will have the shortcomings of basic auth - if you login to nagvis on the basic auth virtualhost, that login will persist until the cache is cleared (like core). This will not interrupt the autologin of the guest account on the other virtualhost. So beware: any machine you login to nagvis through the basic auth virtualhost will stay logged in for that virtual host until 30 days or a browser cache clear, whichever comes first.
So to recap:
1. Make sure to remove any .htaccess files in the /usr/local/nagvis folders.
2. You will need to replace the ServerNames: "nagiosxi.localdomain" and "nagiosxinagvis.localdomain" in the vhost file below (/etc/httpd/conf.d/nagvis) with your two different dns names.
3. Make sure the new dns names have entries in /etc/hosts and that they are mapped to the nagios xi server ip.
4. Verify that the two following directives are configured in /usr/local/nagvis/etc/nagvis.ini.php:
/etc/httpd/conf.d/nagvis.conf:
So to recap:
logonmodule="LogonMixed"
logonenvvar="PHP_AUTH_USER"Code: Select all
# NagVis Apache2 split auth virtualhosts
NameVirtualHost *:80
#GUEST VIRTUALHOST
<VirtualHost *:80>
ServerName nagiosxinagvis.localdomain
Alias /nagvis "/usr/local/nagvis/share"
<Directory "/usr/local/nagvis/share">
AllowOverride All
Order allow,deny
Allow from all
SetEnv PHP_AUTH_USER guest
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /nagvis
RewriteCond %{REQUEST_URI} ^/nagvis(/index\.php|/|)(\?.*|)$
RewriteRule ^(index\.php|)(\?.*|)$ /nagvis/frontend/nagvis-js/$1$2 [R=301,L]
RewriteCond %{REQUEST_URI} ^/nagvis/config\.php.*$
RewriteRule ^config\.php(.*) /nagvis/frontend/wui/$1 [R=301,L]
# Redirect old regular map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/nagvis-js
RewriteCond %{QUERY_STRING} map=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=%1 [R=301,L]
# Redirect old wui map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/wui
RewriteRule ^(.*)$ /nagvis/frontend/wui/index.php?mod=Map&act=edit&show=%1 [R=301,L]
# Redirect old rotation calls
RewriteCond %{QUERY_STRING} !mod
RewriteCond %{QUERY_STRING} rotation=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Rotation&act=view&show=%1 [R=301,L]
</IfModule>
</Directory>
</VirtualHost>
#BASIC AUTH VIRTUALHOST
<VirtualHost *:80>
ServerName nagiosxi.localdomain
AllowOverride None
Order allow,deny
Allow from all
AuthName "NagVis Access"
AuthType Basic
AuthUserFile /usr/local/nagiosxi/etc/htpasswd.users
Require valid-user
RewriteEngine On
RewriteBase /nagvis
</IfModule>
</Directory>
</VirtualHost>Former Nagios employee
