How to restrict user view to single page, no menu's etc
stuartbr
Post by stuartbr »
I'm running a trial of nagios XI for monitoring systems for different operational groups. I'm looking to give selected users access to a single view e.g. the Operations Screen. All other menu's etc should not be shown. Is this possible, if not, it how close can I get to this requirement?
Stuart
Re: How to restrict user view to single page, no menu's etc
Post by slansing »
This is not currently possible due to how the restrictions are set up. You could give a user read only access and then assign their contact to specific hosts/services so they can only see those objects, but they will be able to navigate the interface as any other user could with the exception that they will not be able to Access the Admin page, or change any configuration options on the XI server.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
There is not a real way to prevent them from loading other pages as well, if they click on links and such within the ops screen. However if that is not your concern and strictly opening up that single page is what you are looking for, you can always open a page in a new tab to get the direct uri. Then load that on your other system and verify that it only loads the internal frame.
nagiosxi/includes/components/nagioscore/ui/tac.php - would be the path to the tactical overview.
