I just installed NagioXI on a fresh install of CentOS
It would seem like Nagios Core was not installed correctly as the conf files are not there.
I have my system info, the info i used for my proxy and the error i recieved as well as an ls from my nagios core etc folder
I am going to attempt to scp the conf files from the vmware image of Nagios that I have but I want to get the manual install to work.
1. CentOS 5.6
2. 64bit
3. Manual Install of XI
4. I am using a proxy, but i followed the wiki for wget and yum?
info from the Wiki
"In /etc/yum.conf :
proxy=http://someproxyserver:port/ # Shouldn't need to be quoted, remember the trailing slash
proxy_username=myname # The username you authenticate to your proxy with, if applicable
proxy_password=mypass # The password you provide to your proxy, if applicable
In /etc/wgetrc :
http_proxy=http://myname:mypass@someproxyserver:port/ # All in one string this time
no_proxy=localhost,127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16 # Hosts to exclude from proxying"
*Update to add service restarts per Sticky*
[root@na nagiosxi]# service mysqld restart
Stopping MySQL: [ OK ]
Starting MySQL: [ OK ]
[root@na nagiosxi]# service postgresql restart
Stopping postgresql service: [ OK ]
Starting postgresql service: [ OK ]
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
ERROR: NagiosQL import appears to have failed - exiting. (Reason: Nagios Core configuration is invalid)
[root@na nagiosxi]# ls /usr/local/nagios/etc/
cgi.cfg hosts import nagios.cfg ndo2db.cfg ndomod.cfg nrpe.cfg nsca.cfg pnp resource.cfg send_nsca.cfg services static
NagiosXI install fails at ImportNagiosQL
Re: NagiosXI install fails at ImportNagiosQL
*Update*
I moved the conf from the vmware image to the new server. I moved the files to /usr/local/nagios/etc/import/ but they get deleted in the script it would seem.
So I moved them to /usr/local/nagios/etc/ as well then added the 3 default services and hosts to their respective directories.
Now I get the following error:
RESETTING PERMS
/usr/local/nagiosxi/nom/checkpoints/nagioscore /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
/tmp/nagiosxi
ERROR: Unable to login to NagiosQL on 'localhost' - exiting. If you have a proxy configured, this may be the cause of the problem.
RESETTING PERMS
/tmp/nagiosxi
During the initial install did you start of with?
The reason for this could be permissions if it was not run from this directory and can cause several issues.
If so, was anything deviated from here:
http://assets.nagios.com/downloads/nagi ... ctions.pdf ?
Thank you.
cd /tmp
Thank you.
Yes I followed the install to the letter.
All of my commands were run from /tmp/nagiosxi
Okay,
which version of Nagios XI are you using? Also, did you happen to have to run ./0-yum twice? I have recently seen where this was needed but usually would not get past ./1-prereqs if so.
yes i did need to run ./0-Yum twice.
I ran wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
Please reference this post:
http://support.nagios.com/forum/viewtop ... osQL#p7099
Hopefully that will be of some assistance.
If I were to create a NAT to allow the traffic out of the proxy, Which URL's would I need to point to?
Could you try running this:
http://support.nagios.com/wiki/index.ph ... figuration
Also, I am not quite sure what you mean with your post:
Could you elaborate more?If I were to create a NAT to allow the traffic out of the proxy, Which URL's would I need to point to?
I am running all default hosts and services.
I want to edit /etc/hosts to allow the hosts to get through our proxy to get to api.nagios.org.
Is there anything else I need to do?
