openssh status
openssh status
Hello!
installed nagios3 on Linux Mint. Everything looks good and working,
except: localhost servise ssh - > status ->critical
openssh-server is not installed, only ssh-client
Is it a problem? check_ssh checks only ssh-server?
I also have virtual machine (centos64 openssh-server is installed), I can ping it and all other services checked by Nagios successfully , but the same problem
on Nagios web-interface it says for CentOS host ->ssh status-> critical.
Firewalls desabled on host and virtual CentOS
Any ideas? What shall I do to bring status to OK?
Thank you for your help
Re: openssh status
Yes, you need to install a ssh server for the check to work.vvz wrote:Hello!
Are you able to ssh into the CentOS machine from your Nagios machine?vvz wrote: I also have virtual machine (centos64 openssh-server is installed), I can ping it and all other services checked by Nagios successfully , but the same problem
Re: openssh status
sorry, it's clear now
thank you for your help
now I do now so worry about remore machine
what about local host?
Re: openssh status
I'm not sure I understand your question.
What do you need help with regarding localhost?
Re: openssh status
now I've installed openssh- server on my localhost
in my-host.cfg I have
host_name localhost
service_description SSH
check_command check_ssh localhost
when I run # nagios3 -v /etc/nagios3/nagios.cfg
it gives 1 error
when I comment this section it has no errors
host_name localhost
it gives 1 error
Re: openssh status
Can you provide the error given? Also, please run the "check_ssh localhost" command from the command line and provide the output.
Re: openssh status
check_ssh localhost
WARNING:root:could not open file '/etc/apt/sources.list'
check_ssh: command not found
Re: openssh status
chkng
Nagios Core 3.4.1
Last Modified: 05-11-2012
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config file '/etc/nagios3/commands.cfg'...
Processing object config directory '/etc/nagios-plugins/config'...
Processing object config file '/etc/nagios-plugins/config/dns.cfg'...
Processing object config file '/etc/nagios-plugins/config/games.cfg'...
Processing object config file '/etc/nagios-plugins/config/fping.cfg'...
Processing object config file '/etc/nagios-plugins/config/snmp.cfg'...
Processing object config file '/etc/nagios-plugins/config/hppjd.cfg'...
Processing object config file '/etc/nagios-plugins/config/ifstatus.cfg'...
Processing object config file '/etc/nagios-plugins/config/ftp.cfg'...
Processing object config file '/etc/nagios-plugins/config/procs.cfg'...
Processing object config file '/etc/nagios-plugins/config/rpc-nfs.cfg'...
Processing object config file '/etc/nagios-plugins/config/http.cfg'...
Processing object config file '/etc/nagios-plugins/config/load.cfg'...
Processing object config file '/etc/nagios-plugins/config/tcp_udp.cfg'...
Processing object config file '/etc/nagios-plugins/config/apt.cfg'...
Processing object config file '/etc/nagios-plugins/config/radius.cfg'...
Processing object config file '/etc/nagios-plugins/config/mailq.cfg'...
Processing object config file '/etc/nagios-plugins/config/news.cfg'...
Processing object config file '/etc/nagios-plugins/config/netware.cfg'...
Processing object config file '/etc/nagios-plugins/config/dummy.cfg'...
Processing object config file '/etc/nagios-plugins/config/nt.cfg'...
Processing object config file '/etc/nagios-plugins/config/flexlm.cfg'...
Processing object config file '/etc/nagios-plugins/config/mrtg.cfg'...
Processing object config file '/etc/nagios-plugins/config/mysql.cfg'...
Processing object config file '/etc/nagios-plugins/config/breeze.cfg'...
Processing object config file '/etc/nagios-plugins/config/telnet.cfg'...
Processing object config file '/etc/nagios-plugins/config/dhcp.cfg'...
Processing object config file '/etc/nagios-plugins/config/mail.cfg'...
Processing object config file '/etc/nagios-plugins/config/ldap.cfg'...
Processing object config file '/etc/nagios-plugins/config/check_nrpe.cfg'...
Processing object config file '/etc/nagios-plugins/config/users.cfg'...
Processing object config file '/etc/nagios-plugins/config/ping.cfg'...
Processing object config file '/etc/nagios-plugins/config/pgsql.cfg'...
Processing object config file '/etc/nagios-plugins/config/ntp.cfg'...
Processing object config file '/etc/nagios-plugins/config/disk.cfg'...
Processing object config file '/etc/nagios-plugins/config/real.cfg'...
Processing object config file '/etc/nagios-plugins/config/ssh.cfg'...
Processing object config file '/etc/nagios-plugins/config/disk-smb.cfg'...
Processing object config directory '/etc/nagios3/conf.d'...
Processing object config file '/etc/nagios3/conf.d/generic-service_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/contacts_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/extinfo_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/my-hosts.cfg'...
Processing object config file '/etc/nagios3/conf.d/generic-host_nagios2.cfg'...
Processing object config directory '/etc/nagios3/conf.d/ngraph'...
Processing object config directory '/etc/nagios3/conf.d/ngraph/serviceext'...
Processing object config file '/etc/nagios3/conf.d/ngraph/commands.cfg'...
Processing object config file '/etc/nagios3/conf.d/services_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/localhost_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/timeperiods_nagios2.cfg'...
Processing object config file '/etc/nagios3/conf.d/hostgroups_nagios2.cfg'...
Warning: Duplicate definition found for service 'SSH' on host 'localhost' (config file '/etc/nagios3/conf.d/services_nagios2.cfg', starting on line 11)
Warning: Duplicate definition found for service 'PING' on host 'centos' (config file '/etc/nagios3/conf.d/my-hosts.cfg', starting on line 30)
Checking services...
Error: Service check command 'check_ssh localhost' specified in service 'SSH' for host 'localhost' not defined anywhere!
Checked 11 services.
Checking hosts...
Checked 2 hosts.
Checking host groups...
Checked 5 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 3 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 157 commands.
Checking time periods...
Checked 4 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
Nagios Core 3.4.1
License: GPL
Checking hosts...
Checked 2 hosts.
Checked 3 contacts.
Total Warnings: 0
Total Errors: 1
Re: openssh status
Your check command is incorrect. It should just be:vvz wrote: Checking services...
host_name localhost
}Former Nagios employee
Re: openssh status
You will need to provide the full path name to the command:vvz wrote:check_ssh localhost
/usr/lib/nagios/plugins/check_ssh localhost
^ That should be correct on your system.
Try adding "register 1" to the end of your services just to be sure, and making the change abrist suggested:vvz wrote: define service{
host_name localhost
host_name localhost
register 1
