NSCA Communication issues.
I have a configuration for sending passive check results from a solaris box to centos based nagios xi system.
I followed all the docs I could get on hand to make it work. Interesting part is that send_nsca from solaris thinks that it has sent a datapacket successfully.
But I do not see anything on the Nagios XI server saying it received it.
This works fine when I send from local machine.
here are the example
/opt/csw/nagios/bin/send_nsca 10.2.2.100 -d , -c /etc/opt/csw/nagios/send_nsca.cfg < test2
1 data packet(s) sent to host successfully.
here are the configs
nsca.cfg
password set
encryption_method=2
xinetd.d/nsca
# description: NSCA (Nagios Service Check Acceptor)
service nsca
flags = REUSE
socket_type = stream
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nsca
server_args = -c /usr/local/nagios/etc/nsca.cfg --inetd
log_on_failure += USERID
disable = no
only_from = 10.1.30.130
here are the iptable info
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:nsca
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:nrpe
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
nsca.cfg
password set
encryption_method=2
xinetd.d/nsca
service nsca
flags = REUSE
wait = no
user = nagios
group = nagios
disable = no
Re: NSCA Communication issues.
Do you see anything in Unconfigured Objects? Is "Enable Listener For Unconfigured Objects" check-box selected under Admin->Performance Settings->Subsystem? Did you look for clues in /var/log/messages?
I see this message in the messages file. I made it with no encryption and setup simple password.
Oct 31 21:12:55 localhost nsca[4705]: Dropping packet with invalid CRC32 - possibly due to client using wrong password or crypto algorithm?
The only thing is I am seeing is when i use the same setup from local it works, This does not work when i send from solaris. Is there a difference in crypto algorithms across OS ?
What version of NSCA did you install on the solaris system? And what version of Nagios XI are you using?
We are on Nagios XI Version : 2012R2.5
send_nsca on solaris change log says
NSCA Changelog
2.9.1 - 01/27/2012
How can I know the nsca daemon version?
NSCA Changelog
2.9.1 - 01/27/2012
sujitt,
What Decryption are you using on the XI side?
Admin > Inbound Transfers > NSCA >Decyption Method.
What encryption are you using on Solaris?
-Yancy
-Yancy
You can just run from the command line:
You should be able to see the version. Can you run the following command and show us the output?
I would set the value to "0" (zero), so that no packages would be rejected based on their age, and restart the xinetd:
/usr/local/nagios/bin/nscaCode: Select all
grep max_packet_age= /usr/local/nagios/etc/nsca.cfgCode: Select all
service xinetd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
is the 2.9.1 nsca client backward compatible with nsca 2.7.2 ?
You cannot run a newer version of nsca as the sender (remote host). We would suggest using 2.7.2 on the remote hosts.
are there instructions to upgrade the nsca version on Nagios XI to 2.9.1 ? or it is still not stable ?
