check_nrpe with WMI scripting
mcnabbm
Post by mcnabbm »
COMMAND: /usr/local/nagios/libexec/check_nrpe -H BAMDEV1D1 -t 30 -c CheckWMIValue -a "Query=Select DriveLetter, FreeSpace from win32_Volume where DriveType=3" MinCrit=5000 Check:Disk=FreeSpace AliasCol=DriveLetter
OUTPUT: OK: Everything seems fine.|'C: Disk'=3375972352;0;5000 'D: Disk'=8470765568;0;5000 'P: Disk'=1317314560;0;5000
I finally got the script to work and asked our windows engineer if the information being reported was acceptable and he said he would prefer to set a percentage value then the freespace numeric value.
I have spent several hours trying to find the commands to use to get the percentage. I tried to use "MinCrit=5%" as I saw in a web tutorial but no luck. I need some help.
The other thing is if I want to split it out and write a specific script for each logical Drive, how would I accomplish that?
Re: check_nrpe with WMI scripting
Unfortunately, getting a percentage in the output is not possible with WMI, unless you create a custom script, and do some math with the data. You can probably use check_nt, for example:
/usr/local/nagios/libexec/check_nt -H <ip> -s "password" -p 12489 -v USEDDISKSPACE -l C -w 80 -c 95
C:\ - total: 452.96 Gb - used: 230.62 Gb (51%) - free 222.34 Gb (49%) | 'C:\ Used Space'=230.62Gb;362.37;430.31;0.00;452.96
