All of the nagios instances are now running 4.0.1, and all of the hosts are running CentOs (mostly 6.4 - but the masters are running 5.8).
I have nagios set-up as a service, so in theory, I have a number of options to refresh nagios;
service nagios stop;service nagios start
kill -HUP [pid of nagios]This is also the case with the smaller installations.... but in almost every case, when I do this with the master collectors I get a SIGSEGV error, and nagios is no longer running - it doesn't happen every time.... but it happens MOST times... it appears that this MIGHT be related to nsca processes still running ?
I don't get an issue if I stop / start nagios, as opposed to forcing it to re-read the config file (and I have confirmed that the new config is clean).
So, two questions...
- is there a "best" way to re-start nagios with a changed config ?
- assuming I can re-produce the core file - what other information is required, and what should I do with this ?
Thanks, Malcolm
