Apply Configuration Page Stalls Out, Never Completes
As the title says any configuration attempt will not finish. I am still trying to do the initial configuration. So far Nagios XI only monitoring the localhost.
I have looked at the FAQ on this issue and cold booted the machine. I then completed the recommended configuration changes on /etc/php.ini and restarted.
First, I doubled the values and restarted; same result. Then I trippled the value and restarted; same result.
Installed on a clean brand new machine.
Nagios XI Version : 2012R2.5
Red Hat Enterprise Linux Server release 6.4 (Santiago)
Any suggestions?
Any suggestions?
Re: Apply Configuration Page Stalls Out, Never Completes
What browsers have you tried?
Do a running tail on the apache error log, try to apply configuration, wait a few minutes, kill the tail and post the output of the tail:
Additionally, follow the steps in the faq below and post the cmd.txt file:
http://support.nagios.com/wiki/index.ph ... n_Problems
tail -f /var/log/httpd/error_loghttp://support.nagios.com/wiki/index.ph ... n_Problems
Already tried the recommendations in that post
running tail -f /var/log/httpd/error_log resulted in:
tail: cannot open `/var/log/httpd/error_log' for reading: No such file or directory
cmd.txt contains:
tail: cannot open `/usr/local/nagiosxi/var/cmdsubsys.log' for reading: No such file or directory
tail: no files remaining
cmd.txt contains:
Can you post the output of
ls -la /usr/local/nagiosxi/varRe: Apply Configuration Page Stalls Out, Never Completes
The output was
total 24
drwxr-xr-x 4 root root 4096 Oct 30 09:44 .
drwxr-xr-x 10 root root 4096 Nov 4 07:27 ..
drwsrwsr-x 2 apache nagios 4096 Nov 4 07:22 components
drwxr-xr-x 2 root root 4096 Nov 6 13:22 subsys
-rwxr-xr-x 1 root root 790 Oct 30 09:44 xi-sys.cfg
-rwxr-xr-x 1 root root 202 Oct 30 10:18 xiversion
Good news, the second time i ran the reconfigure script it worked and the hosts were added. I am now in the process of trying from the web interface to see if it completes.
total 24
The permissions on this directory are not right... and it would be hard to say what other item are wrong, but a good start would be to run
chown nagios.nagios /usr/local/nagiosxi
chown -R nagios.nagios /usr/local/nagiosxi/var
chown -R nagios.nagios /usr/local/nagiosxi/cron
chown -R nagios.nagios /usr/local/nagiosxi/nom
chown -R nagios.nagios /usr/local/nagiosxi/tmpRe: Apply Configuration Page Stalls Out, Never Completes
It looks like any reconfigure from the web interface does not work.
If I manually do the reconfigure_nagios.sh then it works.
Do you push configurations or permission to this system with chef/puppet? (permissions, /etc/passwd and shadow, /etc/sudoers, etc) ??
No, everything so far has been done in the installed Nagios XI interface, nothing else
Ok, please send the output of the following
You will likely need to run
ls -la /usr/local/nagiosxi/scriptsYou will likely need to run
chown nagios.nagios /usr/local/nagiosxi/scripts/*
chown root:nagios /usr/local/nagiosxi/scripts/reset_config_perms
chown root:nagios /usr/local/nagiosxi/scripts/reset_config_perms.sh
chmod u+s /usr/local/nagiosxi/scripts/reset_config_perms
chmod u+s /usr/local/nagiosxi/scripts/reset_config_perms.sh
