Nagios or Script Glitche
cesar.garza
Post by cesar.garza »
Hey guys
I need your help to figure it out the problem coming from where (Nagios or Script).
Problem: not getting status information on the nagios UI. you can see in the screenshot that Unknown/CRITICAL is coming with ""service check time out"" info. However when i ran the script in my linux box and got the (HTTP 500 Internal Server Error) message. that was supposed to come there.
Scenario : I have a script that trigger a endpoint and grab the HTTP status code. Script is working fine and give the HTTP status code. But nagios is TAKING only OK message & status code and print in the nagios UI but not other messages like critical/warning/unknown and status code print in the nagios UI.
I have attached a script, if anyone wanna have a look.
Endpoint.sh
(1.51 KiB) Downloaded 316 times
abrist
Red Shirt
Re: Nagios or Script Glitche
Post by abrist »
How long does the check take from the cli?
cesar.garza
abrist wrote:How long does the check take from the cli?
Thanks for your reply but somehow now i am getting the message in nagios UI.
abrist
Red Shirt
Post by abrist »
? So is it working ok now? If not, run it from the cli and let us know how long it takes to finish execution.
cesar.garza
Yes, its working now. there was a minor problem in the script. i just moved the code and it worked.
Post by slansing »
Ah excellent!
