check_bgp Error
check_bgp Error
I am trying to use the following script to check BGP Neighbors/peering on our switches.
http://exchange.nagios.org/directory/Pl ... gp/details
However, I receive the following errors:
[root@vmnagios libexec]# ./check_bgp -help
Can't locate Net/SNMP.pm in @INC (@INC contains: /usr/lib/nagios/plugins /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_bgp line 77.
BEGIN failed--compilation aborted at ./check_bgp line 77.
The file has correct permissions:
-rwxr-xr-x. 1 nagios nagios 9928 Nov 8 09:48 check_bgp
Does anyone have any ideas, or perhaps a better script for BGP peer checks on Aristas?
Thank you very much.
Re: check_bgp Error
What does the following output? It does not look like you have net-snmp installed:
yum list installed | grep net-snmpRe: check_bgp Error
Hello, thank you for the response.
Here is the output:
[root@vmnagios libexec]# yum list installed |grep net-snmp
net-snmp.x86_64 1:5.5-44.el6 @base
net-snmp-libs.x86_64 1:5.5-44.el6 @base
net-snmp-utils.x86_64 1:5.5-44.el6 @base
I have snmp working for our port monitoring on switches currently.
Here is the output:
Re: check_bgp Error
Which version of the check_bgp plugin are you using from that exchange link?
Re: check_bgp Error
I tried to use 0.4 and 0.3. I 'installed' it by creating a file check_bgp and pasting the contents into it. I then changed ownership and permissions.
Re: check_bgp Error
This is a 3rd party plugin. I am not familiar with it, but I wonder if "/usr/lib/nagios/plugins" is the correct path to your plugins directory... If it's not, you can open the plugin in a text editor, and modify it, by entering the correct paths.
Re: check_bgp Error
The path of my Nagios plugin directory is /usr/local/nagios/libexec. Should I modify the code to reflect that?
Thank you.
Thank you.
Re: check_bgp Error
Yes, give it a try and see if this is going to fix your issue.
Re: check_bgp Error
Same error
Can't locate Net/SNMP.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_bgp line 77.
Re: check_bgp Error
It's failing on line 77 of the .4 version, which is the line that says to use Net-SNMP. So it's definitely having a hard time finding the module. Can you run the following and provide the output?
find / -name SNMP.pmFormer Nagios employee
