Installing webinject (split topic)
vivithemage
Post by vivithemage »
Looks like I got it working a bit better, but those sterr I am seeing is probably related to web inject not being installed on this new server. Is there an easy way to run the install for webinject?
Reason: Split topic from http://support.nagios.com/forum/viewtopic.php?f=7&t=21922
Re: Installing webinject (split topic)
vivithemage
I ran through the perl dependencies and installed them ... I see this error in the log a bunch now:
^G[1384286574] SERVICE ALERT: p021_node02;client1207;CRITICAL;SOFT;2;(No output on stdout) stderr: Can't locate Crypt/SSLeay.pm in @INC (@INC contains: /usr/lib64/perl5/site_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib64/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib64/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 .) at /usr/lib/perl5/site_perl/5.8.8/Webinject.pm line 29.
Post by slansing »
Looks like you are missing the Crypt::SSLeay dependencies, please run:
yum install perl-Crypt-SSLeay
vivithemage
okay, now I see:
[1384287348] SERVICE ALERT: p026_node01;client1251;CRITICAL;SOFT;1;(No output on stdout) stderr: Can't locate XML/Parser.pm in @INC (@INC contains: /usr/lib64/perl5/site_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib64/perl5/vendor_perl/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib64/perl5/5.8.8/x86_64-linux-thread-multi /usr/lib/perl5/5.8.8 .) at /usr/lib/perl5/site_perl/5.8.8/Webinject.pm line 30.
vivithemage
ran: yum install perl-XML-Parser
now I see a lot of:
[1384287502] SERVICE ALERT: us002_node01;client6018;UNKNOWN;SOFT;2;ERROR: Failed to open /nagios.xml file: No such file or directory
[1384287502] SERVICE ALERT: t002_node02;train0018;UNKNOWN;SOFT;1;ERROR: Failed to open /nagios.xml file: No such file or directory
[1384287502] SERVICE ALERT: sb005_node01;sb1058;UNKNOWN;SOFT;1;ERROR: Failed to open /nagios.xml file: No such file or directory
[1384287502] SERVICE ALERT: p016_node01;client1160;UNKNOWN;SOFT;1;ERROR: Failed to open /nagios.xml file: No such file or directory
[1384287502] SERVICE ALERT: uat362_node01;uat362;UNKNOWN;SOFT;1;ERROR: Failed to open /nagios.xml file: No such file or directory
[1384287502] SERVICE ALERT: sb003_node01;sb1016;UNKNOWN;SOFT;1;(No output on stdout) stderr:
[1384287503] SERVICE ALERT: us002_node01;client6017;UNKNOWN;SOFT;1;(No output on stdout) stderr:
[1384287503] SERVICE ALERT: t001_node02;train0004;UNKNOWN;SOFT;2;(No output on stdout) stderr:
[1384287503] SERVICE ALERT: client328_node02;client328;UNKNOWN;HARD;3;(No output on stdout) stderr:
abrist
Red Shirt
Post by abrist »
Can you show us the xml config for webinject and one of the failing webinject checks from the cli?
shodg001
Post by shodg001 »
/nagios.xml might be referring to the test case file. Check your config.xml and look for this tag:
<testcasefile></testcasefile>
Mine for example is <testcasefile>testcase.xml</testcasefile>
testcase.xml is located in the same directory as the rest of the Nagios Plugins, to include check_webinject (/usr/local/nagios/libexec) I use Ubuntu.
From the command line I call a web service like so:
sudo ./check_webinject -s baseurl=http://url/ testcase.xml
vivithemage
all my nagios.xml file says is:
<globaltimeout>20</globaltimeout>
<reporttype>nagios</reporttype>
located in:
/usr/local/nagios/libexec/webinject
this is how it is on my old nagios as well, which is not throwing the error.
vivithemage
I ran a test:
./check_webinject -s baseurl=client1261.xxxxxxx.com webinject/401prod.xml
but get:
WebInject CRITICAL - case #1: Failed - No valid HTTP response: 500 Can't connect to ${url}:8080 (Bad hostname)
Content-Type: text/plain
Client-Date: Wed, 13 Nov 2013 16:49:46 GMT
Client-Warning: Redirect loop detected (max_redirect = 0)
LWP::Protocol::http::Socket: Bad hostname '${url}' at /usr/lib/perl5/site_perl/5.8.8/LWP/Protocol/http.pm line 51.
Test: webinject/401prod.xml - 1
Desc: Check LDAP Cache
GET Request: http://${url}:8080/RNJ/action/LDAPCacheDisplay
TEST CASE FAILED : case #1: Failed - No valid HTTP response: 500 Can't connect to ${url}:8080 (Bad hostname)
Response Time = 0.023 sec
Test Cases Run: 1
Test Cases Passed: 0
Test Cases Failed: 1
Verifications Passed: 0
Verifications Failed: 1
|time=0.149;0;0;0;0 case1=0.023;0;0;0;0 case2=0;0;0;0;0
I wonder if the way to reference the bsae_url has changed in the new version?
