check_nrpe returns UNKNOWN instead of CRITICAL
Using check_nrpe I got some situation where some connections problem returned as CRITICAL instead of UNKNOWN even with -u switch specified. I don't know if this is the best approach but the attached patch solve the problem to me.
patch.diff.txt- (427 Bytes) Downloaded 477 times
