Unable to install Linux Agent
lafargeuser
Post by lafargeuser »
Trying to install Linux NRPE agent on CentOS release 6.3 (Final)_x86_64 machine. But coudnt complete. pasting install.log file here.
I have installed OpenStack on above Server & trying to monitor using Nagios.
Nagios Linux Agent Installation Log
DATE: Mon Nov 11 14:43:49 IST 2013
DISTRO INFO:
CentOS
6.3
x86_64
Configuring Yum...
epel-release RPM installed OK
Yum configured OK
Installing prerequisites...
Loaded plugins: fastestmirror, refresh-packagekit, security
Determining fastest mirrors
Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
Servo
Re: Unable to install Linux Agent
Post by Servo »
try to change 'mirrorlist=https' to 'mirrorlist=http'
Run the following commands:
yum clean all
yum update
Then try to install the prereqs manually:
yum -y install autoconf gcc glibc libmcrypt-devel make openssl-devel sudo sysstat xinetd bc
Do you get any errors, when you try to install prereqs this way?
lafargeuser
[root@OpenStack ~]# yum update
[root@OpenStack ~]# yum -y install autoconf gcc glibc libmcrypt-devel make opens sl-devel sudo sysstat xinetd bc
Loading mirror speeds from cached hostfile
You need to set up the EPEL (Extra Packages for Enterprise Linux) repo:
sudo rpm -Uvh http://mirrors.kernel.org/fedora-epel/6/i386/epel-release-6-8.noarch.rpm
then post the output of
yum repolist
to confirm.
lafargeuser
Did install EPEL.
DATE: Thu Nov 14 11:39:45 IST 2013
DISTRO INFO:
CentOS
6.3
x86_64
Yum already configured - exiting.
[root@OpenStack ~]# yum reposlist
No such command: reposlist. Please use /usr/bin/yum --help
Post by slansing »
yum repolist
yancy
Post by yancy »
Also.
ls /etc/yum.repos.d
lafargeuser
[root@OpenStack ~]# yum repolist
[root@OpenStack ~]# ls /etc/yum.repos.d/
CentOS-Base.repo CentOS-Vault.repo foreman.repo
CentOS-Debuginfo.repo epel.repo puppetlabs.repo
CentOS-Media.repo epel-testing.repo rdo-release.repo
Can you post the contents of /etc/yum.repos.d/epel.repo please?
