Not getting notifications with NAGIOS XI
desmondlewissmith
Post by desmondlewissmith »
I setup a LINUX server with 15 services checked.
/var disk space check is setup with Send a notification immediately.
Send alert notifications to… Myself is checked no contacts and no contact groups are checked.
When this partition went to 100% full, the State history does not show the event (happened in the last 24 hrs) and I did not get an email for this alert.
If I look at Nagios Core Config Manager for this same /var check service under the Alert Settings tab, Notifications Enabed is on and Manage Contacts has me (myself) listed and Manage Contact Groups has nothing listed.
I'm trying to figure out why it is that I am not getting notifications.
Plan B is to make Plan A work.
Re: Not getting notifications with NAGIOS XI
Post by slansing »
Can you share your service definition and command definition that is being used?
desmondlewissmith
host_name caisisapp-dev1-16
service_description /var Disk Space
check_command check_xi_by_ssh! -C "/users/tmugrage/usr/local/nagios/libexec/check_disk /var" -l tmugrage -E!!!!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
first_notification_delay 0
notification_options w,c,u,r,f,s,
notifications_enabled 1
contacts tmugrage
_xiwizard sshproxy
register 1
Post by slansing »
You will need to have a host address specified for your check and also a properly defined check command and warning and critical thresholds set up on your service check. In addiction, the contact that is defined here is "tmugrage."
I would review this page first:
http://assets.nagios.com/downloads/nagi ... ng_SSH.pdf
Did you use the wizard to set this up? It appears as though you did but missed a few things.
desmondlewissmith
The notification was setup aulomatically when I ran the SSH wizard. Not sure what you mean by missing a step.
The contact that's defince as tmugrage was me (co-worker) running SSH as a different user because I cannot use the nagios user that environment due to policies. (hence the -l)
jwu
Post by jwu »
is the emailing notification setup?
you might want to see if your email alerts are setup?
send yourself a test mail to start
cstg-infra
Post by cstg-infra »
jwu wrote:is the emailing notification setup?
Are you saying send a test notification from the service check itself? As in the Send Custom Notification command? This has been tested and does not work.
Is "tmugrage" a Nagios XI user or a "contact only". Can you post the contact's definition?
desmondlewissmith
tmugrage is one of the NAGIOS admins. He's actually on this thread now as well. He's one of our sysadmins.
Post by slansing »
