Mass Acknowledgments
rentsys
Post by rentsys »
I navigate to Mass Acknowledgments and click Check All Items then click Submit Commands. It says
Commands processed successfully! Your command submissions may take a few moments to update in the display.
but nothing is acknowledged. How do I fix this?
BanditBBS
Re: Mass Acknowledgments
Post by BanditBBS »
What version of XI and of the mass acknowledgement component are you running?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Post by slansing »
In addition to bandit's question, if you select only one item from the list, does it get acknowledged properly?
rentsys
Post by rentsys »
I am running Nagios XI 2012R2.5, and the component is 1.9 up to date. No, it does not get acknowledged properly.
Try to "Mass Acknowledge" then run the following commands and show us the output:
tail -30 /var/log/messages
tail -30 /var/log/httpd/error_log
rentsys
Post by rentsys »
Here is the output
[root@Juno ~]# tail -30 /var/log/messages
Nov 15 09:56:35 Juno xinetd[15553]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 09:56:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=15553 duration=0(sec)
Nov 15 10:01:35 Juno xinetd[1132]: START: nrpe pid=19329 from=::ffff:10.160.1.49
Nov 15 10:01:35 Juno xinetd[19329]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:01:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=19329 duration=0(sec)
Nov 15 10:06:35 Juno xinetd[1132]: START: nrpe pid=23098 from=::ffff:10.160.1.49
Nov 15 10:06:35 Juno xinetd[23098]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:06:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=23098 duration=0(sec)
Nov 15 10:11:35 Juno xinetd[1132]: START: nrpe pid=26860 from=::ffff:10.160.1.49
Nov 15 10:11:35 Juno xinetd[26860]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:11:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=26860 duration=0(sec)
Nov 15 10:16:35 Juno xinetd[1132]: START: nrpe pid=30688 from=::ffff:10.160.1.49
Nov 15 10:16:35 Juno xinetd[30688]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:16:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=30688 duration=0(sec)
Nov 15 10:21:35 Juno xinetd[1132]: START: nrpe pid=2047 from=::ffff:10.160.1.49
Nov 15 10:21:35 Juno xinetd[2047]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:21:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=2047 duration=0(sec)
Nov 15 10:26:35 Juno xinetd[1132]: START: nrpe pid=5860 from=::ffff:10.160.1.49
Nov 15 10:26:35 Juno xinetd[5860]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:26:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=5860 duration=0(sec)
Nov 15 10:31:35 Juno xinetd[1132]: START: nrpe pid=9616 from=::ffff:10.160.1.49
Nov 15 10:31:35 Juno xinetd[9616]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:31:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=9616 duration=0(sec)
Nov 15 10:36:35 Juno xinetd[1132]: START: nrpe pid=13383 from=::ffff:10.160.1.49
Nov 15 10:36:35 Juno xinetd[13383]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:36:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=13383 duration=0(sec)
Nov 15 10:41:21 Juno nagios: Auto-save of retention data completed successfully.
Nov 15 10:41:35 Juno xinetd[1132]: START: nrpe pid=17151 from=::ffff:10.160.1.49
Nov 15 10:41:35 Juno xinetd[17151]: FAIL: nrpe address from=::ffff:10.160.1.49
Nov 15 10:41:35 Juno xinetd[1132]: EXIT: nrpe status=0 pid=17151 duration=0(sec)
[root@Juno ~]# tail -30 /var/log/httpd/error_log
sh: warning: setlocale: LC_ALL: cannot change locale (en): No such file or directory
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "en_EN"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
[Mon Nov 11 15:44:32 2013] [error] [client 10.150.150.64] request failed: URI too long (longer than 8190)
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "en_EN"
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "en_EN"
[Wed Nov 13 23:03:44 2013] [error] [client 10.160.1.51] File does not exist: /var/www/html/xmldata
[Wed Nov 13 23:03:53 2013] [error] [client 10.160.1.51] File does not exist: /var/www/html/DeviceInformationX
[root@Juno ~]#
The latest version of the component (2.0) is uploading as we speak (it may take a while). It fixes a bug, associated with the locale. It is possible that it will fix the issue that you are having just by looking at the apache error log output.
Download the file below:
massacknowledge.zip
Then install the patched component by going to: Admin->Manage Components->Browse->massacknowledge.zip->Upload Component
Try to mass acknowledge and check if you will see new entries in Home->Acknowledgements.
rentsys
Post by rentsys »
I fixed the bug. Thank you.
I am glad I could help! :D
