Hi all,
i would like to install (new) Nagiosxi 2012 on centos 6.4 64bit server.
What could have caused this error...wrong file.. corrupt file..or ?
Install log:
> Subcomponent 'ajaxterm' installed OK
> --2013-11-14 13:15:52-- http://assets.nagios.com/downloads/nagi ... 86.tar.bz2
> Resolving assets.nagios.com... failed: Name or service not known.
> wget: unable to resolve host address âassets.nagios.com
> â File "./install", line 29, in <module>
> tarname = tarfile.open(wkversion, 'r:bz2')
> File "/usr/lib/python2.6/tarfile.py", line 1670, in open
> return func(name, filemode, fileobj, **kwargs)
> File "/usr/lib/python2.6/tarfile.py", line 1741, in bz2open
> fileobj = bz2.BZ2File(name, mode, compresslevel=compresslevel)
> IOError: [Errno 2] No such file or directory: 'wkhtmltopdf-0.10.0_rc2-static-i386.tar.bz2'
> ERROR: Subcomponent 'wkhtml' installation failed - exiting.
> Subcomponents installation failed - exiting
> RESULT=1
> INSTALLATION ERROR!
> Installation step failed - exiting.
> Check for error messages in the install log (install.log).
> If you require assistance in resolving the issue, please include install.log
> in your communications with Nagios XI technical support.
> The script that failed was: './A-subcomponents'
> [root@szdemhgx5905 nagiosxi]#
thanks for help
Carlos
IEError: wkhtmltopdf-0.10.0_rc2-static-i386.tar.bz2
Re: IEError: wkhtmltopdf-0.10.0_rc2-static-i386.tar.bz2
Please share the output from:
ll /tmp/nagiosxi/subcomponents/
ll /tmp/nagiosxi/subcomponents/wkhtml/
/tmp/nagiosxi/subcomponents/wkhtml/install
